show var
show var {varname}
This is a script command and operates only in scripts or on the command line when scripting is enabled with the following command: enable cli scripting {permanent}.
Description
Displays the current session variables or the named variable.
Syntax Description
varname Displays the variable specified, if present.
Default
N/A.
Usage Guidelines
Use this command to see the list of current session variables. The display includes the variable name and value.
The output of this command is similar to the following:
Switch.7 # show var
Count : 4
variableName                      variableValue
CLI.SESSION_TYPE                  serial
CLI.USER                          admin
STATUS                            0
x                                 66
This command was first available in ExtremeXOS 11.6.
Platform Availability
